| | | Forums66 Topics128,018 Posts1,055,342 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | When I hit the button for my horn, all I get is a barely audible, wimpy sounding beep, not a good, loud blast. I tried different horns, checked to make sure there was a good ground, but it's still the same. Any suggestions? Thanx
My truck: She may not be the prettiest girl at the dance, but she's all mine!
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Pablos49,
I don't know if your truck used a horn relay...I don't think it did. If it didn't, the horn would have two wires, one from the system power and the second for a horn ground supplied by the horn button.
If the horn is powered properly, you should be able to jump the other terminal to a good clean ground and get the horn to blow.
If this happens, it means the wiring or horn button proper is faulty. If it doesn't happen, it means the horn is no good or the wiring to it is loose or poorly connected.
It's possible to use regular jumper cables connected directly to the battery to test a horn. This takes any loose connection or poor ground out of the equation and can sort of knock the cobwebs out and get the vibrator working again.
If your '49 used a horn relay this procedure isn't applicable.
Stuart | | | | | Joined: Nov 2000 Posts: 171 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 171 | Yes use the jumper cables on the horn, the horns are usually on older vehicales adjustable,you might want to look in to that if they don't work right with the jumper cables | | |
