3 members (WICruiser, 3B, GMCJammer51), 114 guests, and 3 robots.
Topics128,056
Posts1,055,796
#621882 02/20/2010 7:36 PM
Casting # 3731548 # on the right pad front bellow head F1204L , What is it?
3B Online: Content
3 Online: Content
Hy BILL, the chevy V8 identification site says that 3731548 is a 1957 283 block, actually kind of a rare engine because it has no side mount boses cast into the block, unlike the 58-67 283 blocks, hope that helps.
1 Offline
That is a 1957, 283, Assembled in Flint on Dec 4, 1956. Are you certain the last leter is an "L"? I do not have a code for that suffix. However, it may be a truck code (all I have is codes for passenger cars).
Joe D
It is suppost to be a 57 truck engine , but on my data plate on my 57 3200 it list 265 V8 and not a 283? , Some where I read that it is suppost to have the "L" =Standard shift, "LA"= hydromatic, "LB"= heavy duty clutch? the engine I have turned out to be a 58 283 ,with the casting for side motor mounts as found in the passenger car.
1 Offline
3731548 may also be a 1957 265 block, which would have been used only with a standard transmission. (Ref East Coast Chevy)
THANK YOU ALL,BILL
F1204L, F= Flint Plant, 1204= Dec 4th assembly date, L= 265, 162 hp, Truck appication w/manual transmission.
Bill Burmeister
It looks like it maybe the engine I want, THANKS again ,BILL
