| | | Forums66 Topics128,089 Posts1,056,139 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 124 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 124 | i thinking about using an hvlp gun to paint my truck. i'm trying to avoid buying a huge compressor. i'm new to auto painting and i have a couple questions.
i'm thinking of painting my truck in parts. ie remove the fenders and paint them one at a time. same for the door, hood ect.
i'm thinking that this technique will require less from the compressor. by that i mean by the time i drain the tank i will be done painting the part.
am i making an incorrest ssumption?
would a lvlp gun be better suited to my situation? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | am i making an incorrest ssumption? For the most part, yes. Get a compressor that has an output rating (CFM, not just PSI) that is above the requirements of your air tool or you're asking for trouble.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Before I had the money to buy a good compressor AND a good moisture-removal system (in 2003), I bought a turbine-based HVLP system (2-stage, Accuspray - now owned/sold by 3M Spray Equipment). This requires no compressor and no air-filter/air-dryer. This is a fine system and comes with an excellent non-bleed, pressure-feed gun.
All my air tools worked fine with a 30-gal 5-hp portable compressor.
In summer 2008, I upgraded to a larger compressor for use with a large media-blasting cabinet (and a larger pressure blaster unit).
| | | | | Joined: Mar 2009 Posts: 124 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 124 | i have seen those turbine units but was unsure of how well they would work with auto paint.
what limmitations did you run into with the turbine unit?
my goal with the paint job is not perfection so i will look into one of those units. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | No limitations. All the advantages of HVLP with none of the liabilities of using a compressor (especially in a high-humidity location). It worked well with high-quality and lower-quality PPG auto paint.
One factor that has to be kept in mind is that the turbine air is warmer than compressor air - a good auto-paint vendor should be able to recommend the right reducer.
