2 members (Peggy M, Simso), 291 guests, and 9 robots.
Topics128,077
Posts1,056,034
Members48,433
RAK
Offline
How tough of a job is this ? Surrounding metal is good and solid.
Should be easy, you should be able to simply unbolt the old one and pop in a new one?
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
Question might be, How easy is it to align the hinge? I can't answer myself but would be interested in the dialog.
HB
~ HB
1962 Chevrolet C10
1962 Suburban
There is adjustment designed into the hinge and the hinge backing plate. If the door closes correctly and the gaps are suitable, replace one hinge at a time, thus holding the door in the correct location. Use a fine point scratch awl, to trace around the edge of the hinge before you remove it. When installing the replacement hinge, put it back in the original location, identified by the scribe lines. I would do the top one first, followed by the bottom hinge.
I hope this information is helpful and let us know how you make out.
Nice tip to consider before removing the hinges. Yes - very helpful.
~ HB
1962 Chevrolet C10
1962 Suburban
