| | | Forums66 Topics128,077 Posts1,056,019 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 192 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 192 | How tough of a job is this ? Surrounding metal is good and solid. | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Should be easy, you should be able to simply unbolt the old one and pop in a new one? | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Question might be, How easy is it to align the hinge? I can't answer myself but would be interested in the dialog. HB | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | There is adjustment designed into the hinge and the hinge backing plate. If the door closes correctly and the gaps are suitable, replace one hinge at a time, thus holding the door in the correct location. Use a fine point scratch awl, to trace around the edge of the hinge before you remove it. When installing the replacement hinge, put it back in the original location, identified by the scribe lines. I would do the top one first, followed by the bottom hinge.
I hope this information is helpful and let us know how you make out. | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Nice tip to consider before removing the hinges. Yes - very helpful.
