| | | Forums66 Topics128,192 Posts1,057,351 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 17 New Guy | | New Guy Joined: Feb 2010 Posts: 17 | All the glass on me 63 is in great shape except the windsield which is foggy from the sun. Can this be fixed or do i need to buy a new one. | | | | | Joined: Mar 2002 Posts: 23 New Guy | | New Guy Joined: Mar 2002 Posts: 23 | Eastwood has a kit to polish out scratches on your windshield it will also clean it up, That's what I'm planing to do to mine. Trucks on spike tv just did an episode about how to do just what your looking to do. Bob | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The glass on these truck are laminated and if they are foggy, it is usually a result of moisture or contaminants between the laminated layers, therefore any topical remedy will not clear up this issue. It is fairly common defect on these trucks, but it is usually isolated to the perimeter. Before making the investment in the glass polishing kit, research your issue, to determine if it is on the surface or within the laminated layers.
Good luck and let us know how you make out. | | |
