| | | Forums66 Topics128,081 Posts1,055,959 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 142 | Hi, I am working on a 1946 Chevrolet Utility, 12 volt system. Upon teardown of the front clip to replace the harmonic balancer and water pump, I noticed the generator end frame is cracked and the flange is damaged. I have a few generators sitting on the shelf, but do not know if they are 6 or 12 volts.
Is there a visual way of determining a 6 volt or 12 volt generator? If not visual, can I use a volt meter to test for 6 or 12 volt?
Dale
| | | | | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | Check the ID tag riveted to the generator.
Black tag = 6v Red tag = 12v
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
| | | | | Joined: May 2008 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 142 | Thanks OlBlue, The generator on the truck is missing the ID tag, and has 12V stamped on it. On the other ones, I am not sure if the tags are still there. What I am interested in is a bench test? Or can I install one off the shelf, mount it on the engine with no wires attached and get a voltage reading? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I ran mine on the bench with an electric motor and belt. With the field grounded and no load it produced 20 volts. That was a six volt. | | | | | Joined: May 2008 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 142 | Great, do you know what the RPM of the motor was? If I use the engine as a test stand, will the voltage output increase/decrease with the engine running at various RPM? | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | Try measuring the field coil resistance with an ohmmeter, from the "F" terminal to the insulated brush holder. Use your known 12V field coils as a reference. If there's a noticeably lower resistance, you've got a 6 volt field coil set. I don't know of a quick way to identify a 6 volt armature. Jerry
Edit: With no wires connected and the armature turning, a polarized generator will produce about 2 volts at the armature terminal, but there's no way to predict where the voltage will go with the field grounded and the armature terminal open-circuited. It would have to be connected to a battery so it can generate some current. Open-circuit voltage can go above 50 volts, and it just keeps increasing as speed goes up.
