2 members (dbwr, 1 invisible), 181 guests, and 0 robots.
Topics128,190
Posts1,057,342
Members48,469
#620972 02/17/2010 10:47 PM
All the glass on me 63 is in great shape except the windsield which is foggy from the sun. Can this be fixed or do i need to buy a new one.
bill 63 #621433 02/19/2010 11:28 AM
Eastwood has a kit to polish out scratches on your windshield it will also clean it up, That's what I'm planing to do to mine. Trucks on spike tv just did an episode about how to do just what your looking to do.
Bob
wojo #621496 02/19/2010 5:42 PM
The glass on these truck are laminated and if they are foggy, it is usually a result of moisture or contaminants between the laminated layers, therefore any topical remedy will not clear up this issue. It is fairly common defect on these trucks, but it is usually isolated to the perimeter. Before making the investment in the glass polishing kit, research your issue, to determine if it is on the surface or within the laminated layers.
Good luck and let us know how you make out.
