| | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 7 New Guy | | New Guy Joined: Mar 2009 Posts: 7 | Hello all, I am looking to put a new (to me) engine in my 54 1 ton. The engine in it has solid lifters. I was thinking of getting a 235 with hydraulic lifters. Good idea, bad idea? Any opinions?
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Once they're adjusted properly, hydraulic lifters are virtually service-free. Sort of a "set 'em and forget 'em" situation. The oldtime complaint about hydraulics pumping up and holding valves off the seats was mostly caused by a combination of weak valve springs and too-high engine speed. One reason for trucks to continue to use solids after the cars went to hydraulic was that the trucks spent a lot of time wound up tight in the lower gears to pull heavy loads. Valves would float, and power was lost from pumped-up lifters if the engine over-revved, even momentarily.
If you're building a hobby truck or a Cowboy Cadillac that never gets used like a truck, go for the hydraulics. Jerry
