7 members (Shaffer's1950, Steelonsteel, Hotrod Lincoln, 2-Ton, homer52, Tiny, mo2cyl), 112 guests, and 3 robots.
Topics128,049
Posts1,055,665
Hello all,
I am looking to put a new (to me) engine in my 54 1 ton. The engine in it has solid lifters. I was thinking of getting a 235 with hydraulic lifters. Good idea, bad idea? Any opinions?
H Online: Content
Once they're adjusted properly, hydraulic lifters are virtually service-free. Sort of a "set 'em and forget 'em" situation. The oldtime complaint about hydraulics pumping up and holding valves off the seats was mostly caused by a combination of weak valve springs and too-high engine speed. One reason for trucks to continue to use solids after the cars went to hydraulic was that the trucks spent a lot of time wound up tight in the lower gears to pull heavy loads. Valves would float, and power was lost from pumped-up lifters if the engine over-revved, even momentarily.
If you're building a hobby truck or a Cowboy Cadillac that never gets used like a truck, go for the hydraulics.
