5 members (Lightholder's Dad, Gdads51, 55shaker, MickeyP, 59 fleet), 85 guests, and 1 robot.
Topics128,118
Posts1,056,304
Members48,439
#620695 02/17/2010 2:39 AM
Moderated
Moderated
will a chev 292 swap with a 236. if not what would be a good choice?
It depends on how much work and modification you are up for.
The 292 and 235 do not use the same bell housing or engine mounts. However, the 292 is a popular swap and lots of people have done it.
As for whether its the best choice for you really depends on what you plan to do with the truck.
The 261 would be a good choice. An easy swap.
Gord
Moderated
Moderated
2 Offline
I put a 292 in my "53 2 ton...It wasn't that bad, since I had the whole front end off. Welding the engine mounts in the right place was probably the hardest part. (And that wasn't that bad.)
Not much room in the front. Had to modify a pulley on the H2O pump and I got an electric fan that works great. Had to add a port in the top of the radiator for the sensor...
I changed everything to 12v with the engine swap, and a 1 wire alternator. I used a painless wiring harness for that- there were a few things I had to modify on the harness, but wire locations worked out well.
Had to stay with the old style transmission, since the new style would not fit. It's tight! The transmission cover had to be modified to fit, too.
Went with cast iron 2pc headers. Can send some pics if you want or answer specific questions....Renee
Moderated by  Dusty53
