7 members (gswbbc, TUTS 59, jmoore, Brian Moore, tclederman, Steelonsteel, BC59), 82 guests, and 3 robots.
Topics128,031
Posts1,055,435
Members48,422
#62060 06/23/2006 3:47 AM
i have a 54 chevy 1/2 ton with hydramatic tranny. I bought a new u-joint with the new rear yoke because my old rear yoke split in half where it connects to the u-joint. now with the new u-joint, how do i install it? i have tried just sliding it on to the driveshaft, but it will not fit between it and the hydramatic transmission. i tried raising the driveshaft, but there is not enough clearance up top to get the yoke on. can i take the crossmember below the driveshaft off and pull the driveshaft down to install it? will it be ok if i take the crossmember off? any ideas would be great! thanks again
1954 Chevy 3100. Original 235 and Hydramatic
www.cardomain.com/ride/2344117
I hope Greg_H answers this one. If you are worried about your Hydra-Mayic hanging in place (safely) without the rear mount (and frame cross-brace) in place, I am certain that there is no danger. Yes, you could then drop the torque tube to put on the rear yoke of the u-joint.
Of course, you should put the rear transmission mount back in place before driving it for long distances.
#62062 06/23/2006 11:44 PM
It will be ok to remove the back mounting bracket and the crossmember that you showed in the pics that you e-mailed to me. You are on the right track.
#62063 06/24/2006 12:12 AM
ok thanks a lot
