2 members (Rich'sToys, Alex52),
123
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | The wipers would only go about 1/4 way up then stop.Is there something i can check?Like the vacum line?Or how/where it is supposed to be hooked up?Found out the other day in a light rain that they "don't"work | | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | is this a vacum problem?I need to know what to check
Danny 1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
| | | | | Joined: Jan 2010 Posts: 113 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 113 | When the vaccum motor hits the spot where it stops can you hear a leak? How do you get the wiper arm to return from the position it stops? Can you move the wipers all the way thru the path by hand? I'm thinking if the arms are free and the vaccum lines are good, your motor may require a rebuild or at least a good cleaning. Check all the hoses looking for cracks, obstructions and so forth. | | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Is there a diagram that shows where vacum lines go? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | There is only one vacuum line. It's connection on the motor should be obvious.
The paddle inside the motor could be dried out. | | | | | Joined: Jan 2010 Posts: 113 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 113 | I'm sure there is somewhere. I'm not familiar with your set up. Here's something you could try. Find a good vaccum source on your engine and run a line from that to the wiper motor there by by passing you orig. line. You should probabley check your engine vaccum at some point as well. I'm sure someone that is more familiar with your truck will pipe in soon. | | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Well my truck is ALL original.Looks like the vacum comes off of the exhaust manifold.But that is why I'm asking.There are a couple of places for "hoses"on that there wiper motor.Original wiper motor I bet also.... | | | | | Joined: Jan 2010 Posts: 113 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 113 | Humm very interesting. The vaccum should be coming from the Intake. There isn't any vaccum in the exhaust.
| | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | I spayed some WD-40 in the breather on top of mine,just to troubleshoot,and that lubricated it just enough to seal up and find the problem.
Jeff | | | | | Joined: Feb 2010 Posts: 28 New Guy | | New Guy Joined: Feb 2010 Posts: 28 | I have repaired a couple of GM vacuum wiper motors and what I found in both was the paddle (which is a hard rubber or hard rubber coated steel, I dont recall for sure) was shrunk/dried up. I took a gamble and soaked the paddle in dot 3 brake fluid and softened it up a bit then cleaned the housing good with brake cleaner. Then lube the softened paddle with white lithium grease (sparingly). Both motors worked great when re assembled. I dont know if this is CORRECT rebuild procedure but poor men have poor ways. | | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | hoses are not hooked up.where do they go on the motor? | | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | | | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Where do they go on the WIPER motor.sorry I guess i should have stated that--- | | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Can somebody explain where/how the vacum lines hook up to the wiper motor?I am assuming that there are 2 lines .One coming from the engine&other going to the wiper arms? | | | | | Joined: Jan 2010 Posts: 113 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 113 | All the vaccum motors I've looked at (not to say there isn't something different) Have a single line coming in with a hole to atmosphere. Vacuum sucks the air thru the (breather) hole, across the vanes of the motor turning the motor, which in turns the wiper arm linkage. What does yours look like? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | There is only one nipple on the wiper motor assembly. Run one vacuum hose from a nipple on the intake manifold to the nipple on the wiper motor. The motor turns the wiper arms by a mechanical connection. | | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | there are these mini lines going to the arms of the wipers.Are those not suppose to be there? | | | | | Joined: Jan 2010 Posts: 113 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 113 | The "Mini lines" are probably the cables that move the wipers. These are not vacuum. | | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | I have a 58 GMC vacuum motor and the arms that accuate the wipers setting on my bench.. I wonder if those "mini hoses" are for the washer nozzles. As others have said there should only be one vacuum line coming from the intake. | | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | You should have one line coming from the intake and connecting to the motor. My motor has two "nipples" on it and it only works with one of them connected. The other doesn't work at all. Turn you engine on, and plug that line onto the nipple, if you have more then one then try either one and see if the wiper arms move. You'll see them move from under the dash.
Those other lines must be for the washer nozzles I assume. My truck doesn't have those. Good luck!
58' 3200 235 3-speed/OD
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | my truck has those mimi hoses BUT i do not have a washer resevoir either. | | | | | Joined: Jan 2010 Posts: 113 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 113 | Got any pictures? Have a friend with a digital camara? | | |
