4 members (baldeagle, Joe H, Bill Hanlon, Jon G), 120 guests, and 4 robots.
Topics128,014
Posts1,055,333
Members48,419
#619900 02/14/2010 9:05 PM
1 Offline
I have a Motorola P.A. speaker from an old state patrol car, and want to hook it up to my CB radio, trouble is, when i have it hooked up and talk into the mic, i can only hear whispers from the PA speaker. I'm just trying to figure out if I need an amp or something to get all i can out of this speaker, cause its pretty heavy duty.
3 Speed Or No Speed
1965 Chevrolet C10 Stepside
1965 Chevy C10 #619940 02/15/2010 12:02 AM
yes, your radio likely doesn't have enough output to drive the speaker, which will be designed for much more volume - although it could also be a mismatch in impedence, check the resistance value of it compared to the regular speaker for the radio
squeeze #620626 02/16/2010 11:34 PM
1 Offline
Thanks Bill, your correct, the radio itself isnt powerful enough, and i KNOW this 400 watt amp i just got will do the trick!
3 Speed Or No Speed
1 Offline
Well, that amp was just a bit TOO powerful, seeing as how I blew 3 CB fuses and somehow turned a set of speaker wire into an arc welder!!!
I've never thought about this, but is it possible to deliver power straight from my battery to the speaker so it doesnt require another source of power like from my CB?
Below are some pics of the Speaker, there seems to be only two terminals, one hooked to the wire going to the CB, and one ground. Maybe I can use another spot on the speaker to ground it and use that free terminal for power? I really know nothing about electronics so I look to you fellas for help, here are some pics.
All I know of the speaker is that it's a Motorola, it weighs about 15 lbs despite its small size, and it came out of a Georgia State Patrol interceptor (not stolen, it was auctioned off).
Overall Picture of the Speaker
Side where the wire to the CB is hooked up
Another side
Side where the ground wire is hooked to the terminal
I'm running out of fuses, unburnt skin and patience!!!
THANKS IN ADVANCE!!!
3 Speed Or No Speed
