| | | Forums66 Topics128,007 Posts1,055,278 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 150 | I have a 1958 cab that I bought. It has rust through in the area where the windshield gasket contacted the metal. Are there any commercially available sheetmetal fixes for this or is this a fabrication job? I'm in the very early stages with this and the 1955 I have in my garage. I want to be ready when the time comes to start work. Thanks! | | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | Where is the rust? Top, bottom or sides? Both sides & the roof can be bought but you have to buy the entire panel and it is expensive. You can try to get used parts & make patch panels from them. That would be the easiest way, or fabricate something. A new roof panel is over $300 and the posts are over $200. 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | | | | Joined: Jan 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 150 | The rust is in the top part of the frame and the sides. There are actually holes. It's funny, the floorpan looks great and I would figure that would be the worst area. I'll try to post a picture of it.
| | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | A lot of times this area is rusted because rodents build nests between the inner outer roof. The urine causes the metal to rust from the inside out. 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | | | | Joined: Jan 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 150 | Well, I may have solved my own problem. I called the DMV to see about getting a title in Texas and it seems to be a pain in the rear. I may just use the parts off of the 1958 cab to build up my 1955 cab. Any idea where to find the fender to cab mount?
| | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | Which one? The lower fender bolt bracket, or the inner fender to cab bracket. 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | | | | Joined: Jan 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 150 | The upper one on the cowl panel. One of mine is missing. My grandfather cut a hole in the cowl panel so he could just drop a bolt through it to hold the upper, rear part of the fender on. | | | | | Joined: Jan 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 150 | here's the link for the rust through pictures. http://s743.photobucket.com/albums/xx73/dougtolliver/I know by combining the two cabs into one good one is the way to go. Do I cut the floorpan out of the 58 and put it in the 55? Do I replace the roof section of the 58 with the one from the 55? I know if I replace the roof I also have to replace the door pillar. I think I may have to get the 1955 media blasted first before I decide. I would love some suggestions from anyone who may have had a similar problem. | | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | I had the same problem with mine. Look HERE and see what I did with mine. 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | | | | Joined: Jan 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 150 | That's what I may wind up doing. Looks good. | | | | | Joined: Jan 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 150 | I was wondering also about welders. I've never welded or anything. I see flux core wire and MIG and TIG welders. Any recommendations on welder type? How about the size of the spot weld cutting bit? If I get these two tools I can start working on my sheet metal. | | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | I have a cheap Harbor Freight flux core welder. I highly DO NOT recommend it. I have welded enough that I can make due with this one, but save yourself a lot of time & aggravation by getting a gas shield MIG. 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | | | | Joined: Jan 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 150 | I saw the cheap ones at Harbor Freight. I think they have a Lincoln Electric Weld Pack at Home depot that's a gas shielded MIG. It may be a flux core. Can you use solid wire in one?
| | | | | Joined: Jan 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 150 | Does anyone out there know what a good size would be for a spot weld bit? Would a 5/16 bit be the right one for sheet metal work? | | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | I have some 8mm and they work great. 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | | | | Joined: Jan 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 150 | Ok, I think that's roughly 5/16 so I'll go with that. I can't find the things locally so I guess I'll order online! | | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | I got mine from a body shop so I am not sure where to tell you to get them. 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Doug,
If you can afford to go with the shielding gas great. If not, flux core will work with a fair ammount of practice to get your voltage correct. Use old scap, etc. to play with first. I used one on my interior cab corner and did a series of good plug welds after using a punch to make that possible. Hank | | | | | Joined: Jan 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 150 | I went ahead, spent the money, and got a gas shielded MIG capable welder. A Lincoln Electric. I wanted to do it right with a minimum of fuss. Now I get to teach myself to weld. I just happen to have scrap laying around too! How did you join the inner cab corners to the outer? They appear to be spot welded at the factory. | | | | | Joined: Jan 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 150 | Eastwood online has them. They also have the panel clamps so you can keep a constant gap while tacking in your repair panel. | | |
