7 members (Donf, 46 Texaco, Southerntruck, Nick in Manitou, Hotrod Lincoln, 2 invisible), 88 guests, and 2 robots.
Topics128,115
Posts1,056,633
Members48,450
JFG
Offline
I am ready to re-install my 216 cylinder head. There is a fair bit of carbon on top of the pistons- perhaps 1/2mm thick in the centres of the pistons. I've tried scrubbing with carb cleaner and a stiff nylon brush, it doesn't do much.
My question is: Can I use any sort of WIRE brush to scrub the piston tops (at TDC) or will that ruin the pistons?
Do they even need to be cleaned at all?
H Online: Content
One tablespoon of carbon buildup on top of a piston will raise the compression about half a ratio, but it won't be consistent from one cylinder to another. The carbon deposits can also glow red hot and promote pre-ignition and detonation on a hard pull. Take an air die grinder or even a high-speed electric drill motor and a fine-bristle wire brush and buff off as much carbon as you can. Just be sure to blow the residue away with lots of compressed air after you finish cleaning.
I guess everyone has their own way of doing things. If I only pull a head, I leave the carbon alone. It will form again any way. Right before I put the head on, I clean each hole with a shop vac.
I do exactly what crenwelge does.
1951 1 Ton Completed
