4 members (DadsFirstPickup, Gray_Ghost, cspecken, 1 invisible), 178 guests, and 5 robots.
Topics128,087
Posts1,056,112
Members48,434
#619088 02/12/2010 1:42 AM
i changed my oil lines to 1/4 pipe w/push on hose, the fiting that gos into the head has a small [censored] hole, ? will my 1/4 in pipe flood the rockers? or whatever?
also, afternoon shop talk, with rocker cover off, my buddy said, looks like valve rotators should be on exaust,i dont know,
thanks ART
Are you talking about the line to the head or the one to the filter. The line to the oil filter has a restriction. The line with a crimped on flex is available from Jim Carter. The line that goes into the front of the head oils the rockers. I think an 3/16 line is correct there. If you are talking about the umbrellas on top of the springs, its for oil control in the intake valves.
