| | | Forums66 Topics128,081 Posts1,056,069 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 25 New Guy | | New Guy Joined: Jun 2008 Posts: 25 | i changed my oil lines to 1/4 pipe w/push on hose, the fiting that gos into the head has a small [censored] hole, ? will my 1/4 in pipe flood the rockers? or whatever?
also, afternoon shop talk, with rocker cover off, my buddy said, looks like valve rotators should be on exaust,i dont know,
thanks ART | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Are you talking about the line to the head or the one to the filter. The line to the oil filter has a restriction. The line with a crimped on flex is available from Jim Carter. The line that goes into the front of the head oils the rockers. I think an 3/16 line is correct there. If you are talking about the umbrellas on top of the springs, its for oil control in the intake valves. | | |
