| | | Forums66 Topics128,043 Posts1,055,612 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 11 New Guy | | New Guy Joined: Jan 2010 Posts: 11 | Hi all, I have a 3/4 ton apache with a 235 in it. and I want to swap that with something with a bit more power, with the least amount of fabrication. I know I could go for the 261, but finding one of those around here is pretty rare. so i was thinking maybe a straight 8? or something like that? Thanks for all the help!!! John
Growing Old Is Required, Growing Up Is Optional  1959 Chevy Apache 36 1939 Chevy Pickup 1951 Chevy Deluxe Coupe | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | A Smallblock Chevy V8 would be the easiest route. You will need to V8 engine mounts (redily avaialable from the resto parts houses) and a V8 bellhousing '55-'59-'63-'72 (salvage yard/swap meet part). A good vehicle to look for if you hit the salvage yards will be the LCF trucks, '55-'59 they were equipped with V8s from the factroy, and will have the bellhousing you will need. This is all assuming you want to keep it somewhat oeriginal and use a manual transmission. If you want an automatic, you'll want to use an aftermarket style crossmember style mounts, one for the engine and another for the rear of the trans. just a side note, don't sell the 235 short. It migh only need a good rebuild. I have a 235 in mine, it'll run 70+ mph all day long and has plenty of power.
Bill Burmeister | | | | | Joined: Jan 2010 Posts: 11 New Guy | | New Guy Joined: Jan 2010 Posts: 11 | Ok, cool!
trust me, I love my 235, and it does need a rebuild. but when it was running good i couldn't get past 50 mph cause of my rear gears (5:13). and since im going to school full time and don't have a job, I'm trying to get this done as cheaply as possible, and cant afford a new axle, and no one makes gears for that rear end. i have an early model 216 that i was thinking of dropping in, but the splash oiling system is like a time bomb to me, and for a daily driver I didn't think it would be a good idea (even though its freshly rebuilt)
Growing Old Is Required, Growing Up Is Optional  1959 Chevy Apache 36 1939 Chevy Pickup 1951 Chevy Deluxe Coupe | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Kid, If your 3/4 ton really does have a 5.14 ring and pinion in it, changing the third member out with a 4.57 unit will gain you a few mph...and they are fairly easy to find. Of course the 4.10 swap would be better, but they are elusive. | | | | | Joined: Jan 2010 Posts: 11 New Guy | | New Guy Joined: Jan 2010 Posts: 11 | it does, and again round here its rare to find used parts that are any good. or cheap... and i can't afford brand new parts. but right now my main priority is the engine swap...
Growing Old Is Required, Growing Up Is Optional  1959 Chevy Apache 36 1939 Chevy Pickup 1951 Chevy Deluxe Coupe | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Swapping an engine because you need higher gears will not give you any advantage. | | | | | Joined: Jan 2010 Posts: 11 New Guy | | New Guy Joined: Jan 2010 Posts: 11 | Cletis,
No disrespect meant, but im not swapping cause i need higher gears, im swapping cause the 235 that is in the truck right now is shot to hell. its gonna take me a couple months to rebuild the engine, and i cant go that long without my truck (it is my daily driver)
Growing Old Is Required, Growing Up Is Optional  1959 Chevy Apache 36 1939 Chevy Pickup 1951 Chevy Deluxe Coupe | | | | | Joined: Jan 2010 Posts: 11 New Guy | | New Guy Joined: Jan 2010 Posts: 11 | I want higher gears for when i put the 235 back in. so that i can go faster than 45-50 (running 4.5-5k RPM)...
Growing Old Is Required, Growing Up Is Optional  1959 Chevy Apache 36 1939 Chevy Pickup 1951 Chevy Deluxe Coupe | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Check all the various places 235s are advertised for sale. The swap meet here, some of the vendors have forums with for sale areas, most the other old truck forums have a for sale area.
Its not unusual someone will be taking out a good 235 to replace with a V-8 and after it sits in the garage unsold for a couple years the price can be very cheap. That could solve your motor problem with very little cash out of pocket.
The rear gears problem is tougher. There is no easy solution. A guy on another board finally found the elusive 4.11 gears and is finding its going to cost an arm and leg to rebuild the rear he has.
My own solution was to replace my rear with a GM 14-bolt with gears I liked better. Other guys have used other axles. I see axles that might work advertised on craigslist all the time in my area, you might find some in yours too.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jan 2010 Posts: 11 New Guy | | New Guy Joined: Jan 2010 Posts: 11 |
Growing Old Is Required, Growing Up Is Optional  1959 Chevy Apache 36 1939 Chevy Pickup 1951 Chevy Deluxe Coupe | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Cletis,
No disrespect meant, but im not swapping cause i need higher gears, im swapping cause the 235 that is in the truck right now is shot to hell. its gonna take me a couple months to rebuild the engine, and i cant go that long without my truck (it is my daily driver) OK, I misunderstood. I'm with OldSub on looking for an idled 235 then. They turn up quite often. | | | | | Joined: Jan 2008 Posts: 239 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 239 | I did same as you want with my first TF, a 57 1/2 ton with 4.10s in it. The old 235 just didn't have enough poop to run more than 55 or so on the highway.
In my local junkyard I found a 66 1/2 ton pickup with 327 and sm420 4 speed. All stock stuff, and worn out too, but better than I had. I bought the replacement SB mounts, dropped it all in and drove it for a couple of years.
Also- Install the tallest rear tires you can without causing problems. That will effectively reduce your rear gear ratio.
Devin
If you can't hose it out it ain't a truck
55 3100 63 Corvair Monza 64 El Camino 72 240Z 01 Suburban
