| | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 252 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 252 | I picked up what I think is a useable set of running boards for my 46 1/2 ton at a swap meet in Nashville, TN yesterday. They both have a few holes drilled through that I'm not too concerned about and should be an easy fix. One board is slightly bent around the rear brace. I have thought endlessy on how to repair it. It may require that I remove the mounting bracket on the back side to repair. I thought about finding a smooth rod that would match the contour of the ribs and try to straighten it out. Any ideas would be appreciated, Thanks G Running Boards 2 Running Boards | | |
