| | | Forums66 Topics128,090 Posts1,056,022 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | I’m trying to keep my ’41 as stock looking as practical. It has a 12 volt system with a generator. It also has the original 6V horn mounted to a cast flange on the intake manifold. My problem is that putting 12 volts on the horn makes it sound terrible. I’ve tried a couple of different resisters with no luck, once hooked up the horn will not work at all.
I’m wondering if there were 12 volt horns that look about the same and could mount to the manifold
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The 6v horns will work on 12v but you may need to play with the adjustment. You should be able to adjust the Klaxon horns if you take the cover off the back. The vibrator probably doesn't have a chance to fully cycle on 12v. Denny Graham Sandwich, IL
Denny G Sandwich, IL
