| | | Forums66 Topics128,026 Posts1,055,399 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#61564 06/09/2006 9:11 PM | Joined: Oct 2004 Posts: 209 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 209 | between the driveshaft to the differential it is leaking. We had put a new seal in it. But still it is leakin. ANy ideas on wat i need to do to fix it. I have no idea? Pictures would help. it is a 64 chevy 1/2 tons. I feel dumb askin this but i am learning as i go on. it is shootin oil onto my tailgate. Please help!!
Stephen
Stovebolt-It is painted
#61565 06/09/2006 10:26 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | First make shure the pinion brgs. are snug. There should be no up & down play in the yoke. If thats ok pull the yoke & see if the srface the seal rides on is smooth. If not a Speede-sleeve is available to go over it. Pull the seal out. You may have damaged it putting it in or let the spring inside fall out. Install a new sealmakeing shure it is the right size. Put a little RTV on the splines of the yoke & the back of the nut. The nut is self locking. If it doesn,t go on tight get a new one. Don,t over tighten it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#61566 06/10/2006 7:02 AM | Joined: Oct 2004 Posts: 209 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 209 | Thanks bro...will check it out.. again thank you for the help...
