| | | Forums66 Topics128,049 Posts1,055,634 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#61386 06/06/2006 10:13 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | I just checked the vacuum on my rebuilt 261 and fiddled with the timing, and got only a mas of 15 inches. I thought it was due to the 3/4 cam or dual carbs, or leaky gaskets or bad valves.
However, after checking all that I talked to a friend and he said that engines produce less vacuum at altitude. Where I live is about 5,500 feet above sea level. My friend said its about 1 inch per 1,000 feet. He said 15 inches is good here and it would be 20-21 at sea level.
Has anyone else heard this?
#61387 06/07/2006 12:41 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | NM51, Yes, two "rules of thumb" might affect your vacuum: ". . engines with performance camshafts tend to read lower vacuum. Readings are also lower at higher altitudes; the rule of thumb is approximately 1 inch of mercury for every 1,000 feet of altitude gain." Tim | | |
#61388 06/07/2006 11:06 PM | Joined: Jul 2005 Posts: 226 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2005 Posts: 226 | heres a way to look at it.. vacuum equals no air.. altitude equals less air... sooooo ya go up to about a bazillion feet altitude, no air, hence a vacuum..... altitude also affects boiling point.. at albqqqqq altitude of 5500 ya say,, id guess the boiling point of water is about 200,,, oh.,,,ps... ya also need to change your timing with alititude.. run more advanced with more alititude if i remember right.... i never time with a light or to specs anway... just run it as far advanced as ya can without pinging...or starting problems when hot...
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
