1 members (JW51),
186
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,077 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 5 New Guy | | New Guy Joined: Jan 2007 Posts: 5 | I would like to swap motors in my 1966 C-10, my transmission is 3 on the tree. I would like to keep the original transmision, has anybody done this and is this a good idea or bad? Would I have to change the gears in the rearend also ? Thanks | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It's an easy swap as the v-8 was available in that truck. It will fit right up to the bell housing & trans. If you still have the early model 292 the flywheel should fit too. The later models had larger flywheel bolts on the 292. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | You will lose a little low-end torque, and probably gain a bit of RPM on the top end. That's good for highway cruising, not so great if you plan to use it like a truck instead of a Cowboy Cadillac. Jerry
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | is something wrong with the 292? even if you are into cubic inches, that's a lot of work for just 8 more. by the time you do the exaust and everything will it be worth it? some think the 305's not the best small block choice but who knows. i think the 292's are a little easier to tune up, faster valve adjustment, dist is easier to reach, handier to change plugs, one head gasket. one manifold gasket, and more room inside engine compartment. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I agree it's hardly worth it unless you go to a 350. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | A direct swap leaves you with the V8 about a foot behind the radiator. Then you have to deal with a shroud or electric fan.
A bigger question than why you would want such a small V8, is why you would want to keep the 3spd? A 350 or bigger with a 5spd or 4spd Auto would be a little more money, a little more work, but a far greater result.
Switching my '67s 3spd for a truck 4spd still left me with a 3spd + granny, but it was a much better truck. Replacing the original 4.56 rear gears with 3.54 was a night/day change. It was the biggest single improvement I have made on the truck, short of the AC. Headers were a slight improvement. Intake and 4bbl was a slight improvement. 3.54 gears put it out on the highway in the fast lane.
'67 GMC 3/4 292 4spd
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Are you talking 305 Chev or GMC? A swap to a 305 V6 would be a step in the wrong direction in my opinion. | | | | | Joined: Jan 2007 Posts: 5 New Guy | | New Guy Joined: Jan 2007 Posts: 5 | The 292 has to completely rebuilt and the 305 (V8) is free from my brother. | | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | nothing wrong with the 305 and in these days of 2.50 gas 305 makes perfect since and pretty much any of the pretty parts you can put on a 350 will fit the 305 just fine plus you have thicker walls remember mouse motor have always been loved for just that reason
1937 1/2 ton
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i hear ya, sometimes you just gotta run what you got. don't junk the 292 someone will want it. you may even want it back after having the 305 for a while.  just kidding, good luck on the swap. hr | | |
