4 members (Maybellene, klhansen, 2 invisible),
87
Mod | | | Forums66 Topics128,211 Posts1,057,468 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 38 New Guy | | New Guy Joined: Jan 2010 Posts: 38 | My 1953 Chevy 3800 wasnt gettinging fuel to the carb. After replacing the the Fuel pump fuel lines etc... I wasnt seeing any differace. I removeved the fuel filter (as it is located justet before the carb) and put a clear peace of fuel line in and watched it as I cranked the engine. No fuel. I removed it from the carb and had fuel!. I opened the carb and saw the float stuck in the up posistion so it wasnt letting any more fule in. The float looked like it was crushed. So once I un stuck it it naturally sunk in the bowel. I orderd a new float. My quesion is what would make it crush? Its a new Carb. I bought it just before the resto about 5 years ago and it hasnt been run until the other day.
If it's broke hit it harder!
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Water in the float bowl and then freezing will crush a brass float.
Grigg | | | | | Joined: Jan 2010 Posts: 38 New Guy | | New Guy Joined: Jan 2010 Posts: 38 | Bet thats what happend. Its been really cold the last couple of weeks and the truck has been sitting with out being started for years.
