| | | Forums66 Topics128,047 Posts1,055,538 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 27 Apprentice | | Apprentice Joined: Jan 2010 Posts: 27 | Can anybody give me some advice for putting seatbelts in a 1948 chev.  | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Check the archives. If you want 3 way belts there is a diagram that shows how to do it.
~Jim
| | | | | Joined: Jan 2009 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 101 | I bought mine from Brothers. It took a little time to install them, but it wasn't that hard. Just make sure you understand where to drill.
Disciple
| | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Just a suggestion.....if you purchase 3 point belts from a vendor (such as Julianos) be sure to specify that you want an extra long inner belt.
I had to add a metal extension up from the floor so that the buckle latch came through the space between the seat back and the seat base. Six inches of additonal belt length over a stock aftermarket set of belts, would have greatly simplified attaching the inner belts to the cab floor.
Also be sure to add a metal triangular reinforcement piece to the upper mount area. The stock sheet metal without the reinforcement will not adequately provide a secure upper mount. I have some pictures of the upper reinforcement in my Webshots Chevy albums. Hope this helps.
Dave
"Buckle Up".....it's a lifesaver!!!!
Dave
| | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | i have always liked the simple yet effective VW beatle seat belts
1937 1/2 ton
| | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | Fla54Chevy3100 Would you post the link for your seat belt pics? Thanks...
Nice 54 you you have...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
| | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Healingbear.....sorry, I thought I had done a better job of documenting the belt install.....checked my pics and added the one that shows the completed mount in my "Tips and Tricks" webshots album. I've given you a few suggestions and basically show you the location that worked for me. Check page 12 of the T&T webshots album.
Dave | | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 |
