1 members (porsche),
111
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,051 Posts1,055,767 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 30 New Guy | | New Guy Joined: Nov 2009 Posts: 30 | Have any of you converted to power brakes and gotten rid of the hydrovac? What units did you use and what location did you choose? under floor, fire wall etc....
Thanks, Pappy | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | If the hydrovac is working right, you will have all the brakes you need. Parts are still available for the hydrovacs. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If you will have power steering then a hydrobooster is a great option. They use PS pump pressure to help apply the brakes, and work very well. That's what I have on my 48.
Grigg | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | I have a hydrovac on my 2 ton parts truck. was contemplating putting it on my one ton. Will this work? anyone ever done this? | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | It will work, but you will have to learn to drive it because it can put you through the windshield if you are not careful. It will be a whole lot more touchy than today's vehicles with abs. It will be kind of like learning to drive with air brakes back in the 60's. | | |
