2 members (Otto Skorzeny, Johnny N), 82 guests, and 0 robots.
Topics128,076
Posts1,055,924
Members48,430
#611653 01/20/2010 4:51 AM
Apprentice
Apprentice
Just got my 235 put back together and cranked. runs great. BUT.. Im not getting oil up in the rocker assembly like i should. I checked my oil filter can and its pumping oil into it but i dont know if its pumping enough. Any advice would be greatly appreciated. Thanks.
Working on a 1949 Chevrolet 3100 3 window with a 58 235.
http://www.mypowerblock.com/profile/Jason77268
What year and application 235 is it? There's differences in the oiling system over the years that the 235 was produced, so having the year/application will help with specific diagnosis.
Bill Burmeister
Apprentice
Apprentice
Well the 235 came out of a 57 chevy car. The head? well i dont know. Got it off a 235 in the junkyard. My truck is a 49 chevy.
Alright. On a '57, there is a 1/8" line that comes from the rear cam journal to a port about at the center of the block, just under the deck surface. That line feeds the rocker shaft. If it's plugged, or I've also seen reports of it simply missing and the cam port plugged off, that will impede oil flow. There's also a passage and/or a special grooved head bolt in the location next to the rocker shaft feed pipe. If that's plugged or wrong bolt intalled, that will block the flow as well. A quick way to check if oil is getting at least to that point is to remove the 1/8" NPT plug that's located on the RH side of the head, about 1/2 way back from the front of the engine. If you get oil there, the line is OK. If the bolt/passage checks out, look for pluggage of the rocker shaft feed pipe.
Bill Burmeister
Apprentice
Apprentice
thanks for the help. I believe i have left out the tube behind the lifter plate. Ha! But I do not believe that any of my head bolts were grooved. I will recheck. I have also read in the forums just now that the grooved head bolt was not incorporated until 1958 when they did away with the tube? Is this correct? Thanks for all your help. Also this is the link I read....
http://1954advance-design.com/Web%20images/1958-60-rocker-oil/1948-57-rocker-arm-lubrication.html
I was thinking that the grooved bolt was on the earlier splash oilers, but I may be wrong. I don't recall the one in my '55 being different, but I marked my bolts when i took them out so that they went back in the same holes.
Bill Burmeister
That's Tim's website. You can thank him personally! He hangs around here quite often with great information. I believe his handle is 'tclederman'
Patrick
Apprentice
Apprentice
Cool. I sent him a PM. Thanks for the help guys. This was my first question but now im obsessed with reading every post just learn what i can.
