2 members (Otto Skorzeny, 1 invisible),
136
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,109 Posts1,056,266 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 8 New Guy | | New Guy Joined: Jul 2007 Posts: 8 | What modifications would need to be made to fit a 261 into a 1950 3100 with a 216?
Thanks, Ron | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What year 261? Will you end up 6v or 12v
If it is a 54-55-1st, not many modifications would be needed.
1955-2nd through 1963 261 would most likely require (at least): - a modification of the front motor mount. - use your 216 clutch housing and clutch assembly. - 6v or 12v? - 6v or 12v generator/alternator? - you would most likely want use a water pump relocation plate on the 261. - an adapter for the oil pressure sender would be needed.
All of the above have been discussed regularly in the past. Spend a little time reading past posts ( and maybe try the "search" feature, which takes a little getting used to).
Maybe others will make additions and corrections to the list - and maybe people will provide links to previous discussions (I'll do that later, when I get home - tomorrow, maybe).
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The throttle bell crank will have to be modified. It is different on the 261. | | | | | Joined: Jul 2007 Posts: 8 New Guy | | New Guy Joined: Jul 2007 Posts: 8 | The 261 is out of a 1957 6500 | | |
