7 members (32Fordpuchoptop, Nhluvstruck, 1955 1 Series, Steve 210, DHedrick, Bill Hanlon, 1 invisible), 153 guests, and 1 robot.
Topics128,114
Posts1,056,283
Members48,439
#611443 01/19/2010 6:04 PM
What modifications would need to be made to fit a 261 into a 1950 3100 with a 216?
Ron
What year 261?
Will you end up 6v or 12v
If it is a 54-55-1st, not many modifications would be needed.
1955-2nd through 1963 261 would most likely require (at least):
- a modification of the front motor mount.
- use your 216 clutch housing and clutch assembly.
- 6v or 12v?
- 6v or 12v generator/alternator?
- you would most likely want use a water pump relocation plate on the 261.
- an adapter for the oil pressure sender would be needed.
All of the above have been discussed regularly in the past. Spend a little time reading past posts ( and maybe try the "search" feature, which takes a little getting used to).
Maybe others will make additions and corrections to the list - and maybe people will provide links to previous discussions (I'll do that later, when I get home - tomorrow, maybe).
The throttle bell crank will have to be modified. It is different on the 261.
1951 1 Ton Completed
What year 261?
The 261 is out of a 1957 6500
