1 members (CuzzFuzz),
228
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | Just picked up a Century(big red) welding unit(for a song-50.00-and it works),don't have any info on it,anything would be helpful.American made.
| | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | Do a google on it and you can probably download the manual for it free..
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
| | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | | | | | | Joined: Jan 2010 Posts: 2 New Guy | | New Guy Joined: Jan 2010 Posts: 2 | Have used same one for 10 years Century 155 .Only concern is replaced the cable wire feeds thru 3 times. replacement had at Merriam Graves( Air Gas ??). I also went to.23 gauge fluxless.Superior to next size up. | | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | Is yours the (Big Red)220v with the flip up lid on top and horizontal spool?I'm just looking for manuals and what-nots for it. | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | I purchased a Century GS125 portable MIG welder...came with a gas hookup so I added a bottle after issues with quality of flux-core welds on light sheet metal. This particular model has no solenoid gas flow control and the cheesy pinch valve in the handle gave out after 6 months. No solenoid shut-off valve for gas when you released the trigger......had to shut off the bottle after each weld. No replacement parts.
Replaced it with a Hobart 140......there is no comparison...the Hobart was a keeper from day one. Hope your Century model works out for you.
Dave | | |
