0 members (),
132
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 95 | Why are Chevy's and GMC's of the same year grounded differently? | | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | Because that's the way they made them. If you don't like pos. ground connect it up the other way. Make it neg. ground. I'm betting someone comes in with the technical aspects of why it was done either way. I changed two of my tractors from pos to neg and they don't know the difference.
Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
| | | | | Joined: Aug 2009 Posts: 295 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 295 | I think the answer "that is the way they made em" is about as good as it gets from a technical aspect. Light bulbs and motors will not care if you change from neg to pos ground. What may care is a generator that is used to one way and if I recall correctly while your ignition will work it is hard on teh contacts when you change grounding.
Best bet LEAVE IT ALONE MARK YOUR BATTERY POSTS WITH PAINT MARK YOUR POS POST CABLE WITH RED TAPE
Dan Bentler | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | At one time, it was believed that commercial vehicles would have fewer grounding and corrosion problems with a positive ground system. That's not very likely, but it represents the engineering theories of 60+ years ago. If you decide to switch the ground polarity, swap the wires on the coil primary so the + lead is connected to the ignition switch, and the - terminal goes to the points. Also, re-polarize the generator by momentarily touching a jumper wire from the Battery terminal to the Armature terminal at the regulator. The regulator is supposedly polarity-sensitive, but I've seen a lot of them work OK on reversed polarity. It's possible to buy aftermarket regulators that are designed to work either way, but try the original one first. If it was my vehicle, I'd leave it original, and just mark everything so it's obvious what the ground polarity is. Jerry
| | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hope I can get a question in here. I am not sure about other year Chevy trucks but on my 3100 235 engine...why is the coil face down in the manuals? Was there a reason? With mine, my dad put it face up .
1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | GMC as well as most larger trucks used a positive ground because lights, especially on the trailer, loose ground a lot quicker due to corrosion of dissimilar metals with negative ground. In fact Freightliner used positive ground until the 70's when drivers got electronic gadgets such as cb radios and demanded negative ground. Most trailers today are built with 2 wires going to each light instead of grounding to the chassis. GMC was built as a big truck while chev didn't get bigger than 2 ton until the task force series. Trucks did have less grounding problems with positive ground. I was driving them and fixing them in those days. I don't want to go into a lengthy discussion, but if you read about corrosion between two unlike metals, it all depends on which way the current if flowing. | | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | I think the upside-down coil was an effort to prevent condensation from collecting in the high-voltage tower of the coil, back when plug wire boots left a lot to be desired in the waterproofing department. Of course, the distributor cap had six plug wire terminals, plus a coil terminal to collect moisture, all facing up, so the theory was flawed, IMHO! Jerry
| | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Jerry, Good to know. I was curious about that. But makes sense to me. I am hanging mine upside down like the manual! Crazy stock original look guy here! 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | |
