7 members (55shaker, Jeff Ogden, RoadsScholar, Gray_Ghost, Ponchogl, fonz8261, 1 invisible), 82 guests, and 1 robot.
Topics128,131
Posts1,056,722
Members48,454
#609524 01/12/2010 10:11 PM
Does anybody know how good of a build can be done to the saginaw 3speed tranny? Im puting a 396 in my 63 in the spring and want to keep the coloumn shift. How much hp and torque will this tranny take? Would I be better with a hd 3speed
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
How are you going to drive it? How are you going to load it?
If used gently it may last a long time. If abused the HD 3-speed won't last either.
Just an everyday driver. I plan to build around 350-375hp engine running on pump gas. This will not be a race truck. Just want to be sure that I'm not going to rip the tranny out w/normal driving
There are people running the Saginaw 4-speed behind 454's successfully, and since that 3-speed is basically the same design I'd expect normal driving would be fine.
Pulling a heavy trailer or drag racing would change my opinion and possibly your experience.
Are you sure you have a Saginaw? If first gear is not synchronized, then you probably have the Muncie SM318, although it is often referred to as a Saginaw. It's the most common transmission they used in the 6cyl cars and 1/2 ton trucks back then. It was available in the trucks until around 1967. As OldSub said it may last for years if driven easy, but they don't like abuse. I had a mild 327 in my first '65 pickup as a kid, and I busted several of them. But of course I was asking for it. Best of luck.
TruckNut
Be kind, courteous, cheerful and helpful - And someone will take advantage of you.
"Quiting smoking is easy, I've done it hundreds of times." Mark Twain
1st gear is not synchronized so its probably the muncie. I have the casting numbers somewhere. Would the saginaw be a better choice of trans? I want to retain the coloumn shift. I have the 12bolt truck reared w/3:73 gears
Here's a little food for thought, the SM318 was used behind 396s and even 427s as the standard equipment transmission in passenger cars. It also saw use behind Feullie 283s, Power-Pak 2x4bbl 283s, Feullie 327s, 348s, and even the 409. Driven normally, and not abused, it should be fine.
Bill Burmeister
If your synchro gear and shift forks aren't worn like a lot of them are, with todays lubricants it should last a long time.
