0 members (), 83 guests, and 0 robots.
Topics128,049
Posts1,055,740
#609010 01/11/2010 4:40 AM
Hi all. I need to replace a section of the passenger side cab toe board on my 53' GMC. Jim Carter only has the entire toe board section. Does anyone know of a supplier that has the cab toe board replacement pieces in seperate pieces?
Hi Doug,
Two options that I know of: 1. buy the complete toeboard and use the section that you need, or buy the passenger side floorpan with passenger side toeboard attached and use the section that you need. Chevies of the 40's has the half floorpan/toeboard for $116, other vendors carry it also.
Samantha
1954 Chevy 3100
Picked from the Field
Follow in the DITY
Samantha,
I will probably go with option 1 since I have already purchased the floor pan. Learning something new all the time!
Thanks for your help,
Doug.
