| | | Forums66 Topics128,162 Posts1,057,049 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 2 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2005 Posts: 2 | have 57 panel and cannot find the vin numbers,thanks. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | if you mean you can't find it on the truck, it should be on a small metal tag on the driver side front door post above the dog leg ... might also be stamped into the frame rail just behind the steering box, 57 is the year that was started ... if not at either of those places ....  Bill | | | | | Joined: Sep 2005 Posts: 2 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2005 Posts: 2 | IS THEIR ANY OTHER LOCATION ON THE BODY,THE CHASSIS HAS BEEN REPLACE.THE DMV WANTS TO LIST MY PANEL AS A 2009.THANKS | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | no - many DMVs do that when tags and titles are lost
Bill | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | ...57 is the year that was started ...
Bill Stop by some time and I'll show you a 1956 that has it. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I'm sure various plants started at different times, I parted out a 57 that didn't have a frame number, and the 58 frame I built into a 57 didn't have one either .... mighta been Canadian tho' they were always last in line  Bill | | | | | Joined: Jun 2009 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 118 | BJFL70, can't you just by a reproduction tag and stamp it to match? Unsure if they repop those tags or not? | | |
