0 members (), 256 guests, and 3 robots.
Topics128,149
Posts1,056,818
Members48,456
Is THIS accurate? if so would swapping the 235 I have with one of the 4200 inline 6 engines be wise? I plan on this becoming my daily driver, would the mount line up? What would i need to do to prep for this? I am planning on getting a 700R4 tranny will that work with this a friend told me there are many variations of the 700R4 is that true?if so what would be the best automatic version to use for this application?
1953 GMC 3/4-Ton Truck
Wanna know more about me heres my Myspace
The 4200 is a good engine, but retrofitting it is neither cheap nor easy. Check this thread on the Inliners forum for some info and contacts.
http://www.inliners.org/ubbthreads/ubbthreads.php?ubb=showflat&Number=44267
regards,
Leon
that was some good info on the engine does anyone know if the 700R4 will mount to it? are there different versions of that transmission? and I also read on the inliners page that id have to retrofit a carb to it I couldn't just run Fuel Injection on it?
