6 members (TexasJim50, Stovebolt48, 32Fordpuchoptop, lumbersawyer, JW51, 1 invisible), 56 guests, and 0 robots.
Topics128,080
Posts1,055,945
Members48,430
#60847 05/24/2006 5:28 AM
Junior Member
Junior Member
Should I use a new oil pan on the freshly built 250 that I am going to put in my truck? If so who sells a replacement? The oil pan isn't beat up I just wondered if they were available.
#60848 05/24/2006 4:18 PM
If there ain't nothin' wrong, don't fix it!
Whenever you remove and replace a pan/cover like the oil pan, valve cover, pushrod cover, differential cover etc... you should take a few minutes to flatten the area around all the bolt holes before bolting the pan back on.
