| | | Forums66 Topics128,154 Posts1,056,838 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 44 | Just picked up a 1999 3rd row bench seat from a suburban...looks good in the truck... Was wondering if anyone has found a "store bought" option for mountings above the gas tank..would like to have an adjustable seat, my wife likes to drive it and she is quite short  Any insights would be appreciated Craig
Craig 1946 Chevy Mod Truck
| | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Craig, I'm using a Glide Engineering seat in my 46. You might be able to mount your seat similar to what I did. I bolted a piece of 3/4" plywood on top of the seat riser and mounted the seat to that. My seat is not adjustable but you should be able to get some adjustable mounting brackets from the junk yard that should work. If you want, email me directly and I can send you a few pictures of what I did for my 46. Hope this helps George | | |
