3 members (Bill Hanlon, baldeagle, Otto Skorzeny), 41 guests, and 5 robots.
Topics128,012
Posts1,055,318
Members48,419
#607264 01/05/2010 4:47 AM
On my '54 GMC 248 I disconnected the tube to the vacuum advance from the carburetor and checked the reading there. The manifold port has a hose to the power brake booster. I left it connected.
The book says I should get a reading of 18-24. I get 9.
Which port should I be checking? Should the other port be capped?
Cletis #607270 01/05/2010 5:01 AM
You want to measure the vacuum from the intake manifold port. This is where you put the gauge for tuning. You can leave the dizzy vacuum connected for this.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Cletis #607273 01/05/2010 5:04 AM
You should be checking vacuum on the manifold port. I know because I made the same mistake. Plug the other port or keep it connected to your distributor.
norcal49er #607472 01/05/2010 11:24 PM
Riding in the Passing Lane
There should be an outlet for w.wipers. Use that one for vacuum testing.
1972 Chevy c10 Cheyenne Super
Thanks guys. I'll check the manifold port when I get back to it.
Cletis #607667 01/06/2010 6:13 PM
The distributor port should get zero vacuum at idle, and it should increase as the engine is revved up. I doubt if it will ever get quite as high as full manifold vacuum. For tuning purposes you need to monitor the vacuum at the manifold, not the distributor port.
Cletis #607698 01/06/2010 8:18 PM
We check the vacuum at the manifold wiper port and we disconnect the vacuum line to the dizzy and plug it on our 235 for timing. This method as per my uncle.
