4 members (Bill Hanlon, Hotrod Lincoln, crenwelge, 78buckshot), 73 guests, and 0 robots.
Topics128,080
Posts1,055,951
Members48,430
My 53 1 ton panel--Ruby-- is making me crazy and I really need some advice and a fresh perspective on the problem.
Here is her condition:
1. 261, holley weber 2bbl, HEI.
2. just adjusted the valves
3. HEI is used, new rotor, cap; replaced pick up with one off of a unit that was working when the shaft broke so I think it is ok.
4. Ball on flywheel and pointer line up @ #1 cyl. TDC and that is where I set the timing.
5. 19" vac. @ idle.
THE PROBLEM: I had to replace my old HEI when it wore out and I can't get this new set up to run smooth; the old one did. on acceleration it is like the timing is totally off --sputtering, bogs down, no power until about 40mph when it sort of smooths out if you keep a very light foot. Pops some through the exhaust when I let off the gas. I did check for vac. leaks and fixed one at the carb but realy didn't see much improvement. At idle she holds a steady 19" and the vac. advance seems to work. I don't want to have to put her down. Anybody got any idears? I keep seeing that old Mauldin cartoon from WWII of Willie with his
.45 pointed at his jeep and I just gotta' fix her.
Check the plug wires to see if a couple have been crossed. I did that a while back, took a little for me to figure out what I had done.
What wore out on the old HEI. If you still have the old dizzy compare the pick up and the mechanical, vacume advance. Make sure that you didn't get a pick up for one of the odd fire six cylinders.
Timing is not nearly advanced enough, advance at least 10 degrees.
Thanks, I will try all these things. People talk about advance/ retard degrees but how much in distance/space on the flywheel is a degree?
On a 12 inch flywheel it would be about a tenth of an inch per degree, or about an inch for ten degrees. Just advance the timing until it pings under load then back it off until it no longer pings. The fact that it smooths out when the centifugal advance is all in but falters if you give it much throttle (because the vacuum drops and you lose the advance due to vacuum) are good indicators of insufficient advance.
Thanks. I have to do an installation this morning but will try all this later today or tomorrow and will report the results. Don
