3 members (Otto Skorzeny, 1955 1 Series, Wheelie), 165 guests, and 2 robots.
Topics128,081
Posts1,056,078
Members48,434
#606396 01/02/2010 5:14 AM
Help-- I am trying to install a new frame mount pedal power brake setup from Speedway. I have been under the impression that there is an adjustable rod between the booster and the mastercylinder.
All there is a stud with a nut on it coming out of booster(7 inch dual) going to the 1 inch dual mastercylinder.Speedway is telling me that there is no rod.
I did find out that they are using a MBM booster and there is none shown at the MBM site. Is this right?
I dont have that particular set up,mines from MP Brakes and the only adjustable rod on mine is between the pedal and master cyclinder....dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
The "stud with a nut" is an adjustment point. It is to adjust the interface spacing between the booster and M/C. There should be around 1/16" gap at rest between the "stud" end and the contact point on the M/C. Too small a gap and the brakes will drag, too large and you will have excessive pedal drop before brake engagement. The actual adjustment is hard to do because of the socket in the M/C where the ball goes. But there is a cheap tool to help you. It looks like a sheetmeat 'H' with a movable rod thru the crossbar in the 'H'. With that said, normal pedal adjustment is with the rod as Davis Dyehouse said.
Thanks for the info. I will proceed to get this thing in now.
Ed
