0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 30 New Guy | | New Guy Joined: Nov 2009 Posts: 30 | My truck has a welded on gas tank about 40 gal. heavy guage steel (the fill cap says "fuel oil", kinda cool). The tank is welded to the frame with some monsterous welds. The truck has been sitting for some time is there some type of additive I can use to "clean" the tank? Or atleast prevent crap from getting into the fuel line. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | It's going to be pretty difficult to clean the tank without removing it. I've never heard of a tank being welded to the frame. Since the cap says fuel oil, it probably wasn't built to be a gas tank in the first place. Fuel oil is what you use in an oil fired furnace. | | | | | Joined: Oct 2007 Posts: 568 'Bolter | | 'Bolter Joined: Oct 2007 Posts: 568 | | | | | | Joined: Aug 2009 Posts: 295 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 295 | Your only choice is to filter the fuel. I would install a diesel type particulate and water separator for best results.
Dan Bentler | | |
