9 members (walter74, Sjm, Wooley, SmalltownTRKGuy, baldeagle, Sjm, Hotrod Lincoln, cmayna, Woogeroo, 1 invisible),
333
8
Mod | | | Forums66 Topics128,165 Posts1,057,089 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 105 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 105 | i just got this last night at O'reillys. http://i942.photobucket.com/albums/ad263/bluecarpenter/2010-01-01104041.jpg They ordered this in and said it will fit my 235 motor. I needed it sooner than could get one ordereing it over the internet. it doesn't look like the one I've seen pic of that is all metal in my catalogs. i know it doesn't have a glass bowl on top but that is fine. WILL it work even though i may have to reroute my plumbing a bit? thanks mark | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | No, the arm is all wrong. Looks like a F**d pump.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2009 Posts: 105 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 105 | i'm getting ready to pull the other one off and look at it but something tells me it won't work either. just needing everyones input. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | The arm is totally wrong,it will not work. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | What is the brand and the part number?
| | | | | Joined: Oct 2009 Posts: 105 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 105 | | | | | | Joined: Oct 2009 Posts: 105 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 105 | the brand is: Airtex
part number is : 4149 | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | I don't think you have the right pump. If you look on the Airtex web site, the picture for the #4149 is not what you have. Maybe O'Reilly can get you another.
regards, Leon
| | | | | Joined: Oct 2009 Posts: 105 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 105 | your right. i called them and they said it was probably packaged wrong. they ordered 2 of them and will have them in the morning. hopfully one of them will be right. mean while i can at least get my mr.gasket fuel pressure regulator plumbed in. | | |
