2 members (rick46ia, Hotrod Lincoln), 72 guests, and 4 robots.
Topics128,022
Posts1,055,352
Members48,420
#606073 01/01/2010 1:42 PM
After looking at the tech tips last year to find the best way to give my stock 41 a cruising speed greater than its current 35MPH I found the great tip from Kip @ http://www.stovebolt.com/techtips/tranny/bonds/index.html.
After much searching this side of the pond I found a 59 3.90 and my wife purchased it for my Christmas smile
http://i360.photobucket.com/albums/oo45/dalbuie/41%20Chevy/P1010002.jpg
http://i360.photobucket.com/albums/oo45/dalbuie/41%20Chevy/P1010003.jpg
http://i360.photobucket.com/albums/oo45/dalbuie/41%20Chevy/P1010004.jpg
Looking at the tech tip it 'looks' a straightforward swap - and I need to get my prop changed anyway as it's a bit bent - but any advice on the swap would be appreciated.
Can't wait for the weather to warm up a bit so I can get it changed and plan to use the truck far more with the better speed wink
For those who believe, no proof is necessary.
For those who don't believe, no proof is possible.
41 Chevy
Dalbuie #606099 01/01/2010 3:50 PM
Riding in the Passing Lane
I wasn't familiar with the light duty 1/2 ton type rear end in a 3/4 ton but if that is what you have it should be an easy job. The tech tip explains it well. If you have any questions post them & there are plenty of knowlegeable people on this website to help.
1972 Chevy c10 Cheyenne Super
41 Chevy
Dalbuie #606151 01/01/2010 5:47 PM
Hi dalbuie:
What a great Christmas present !! looks just like mine.
On my truck it really was that easy !!
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
Kip's41 #606185 01/01/2010 7:10 PM
Originally Posted by Kip's41
Hi dalbuie:
Fingers crossed mine is the same.
You mentioned in the tip you fitted a 61 yoke and I as I have to get a new prop built as well I wondered where you got the yoke?
41 Chevy
Dalbuie #606239 01/01/2010 9:45 PM
Just so happens that I have one, still attached to 6” of cut off drive shaft. I bought it from a local wrecking yard. However when I took my drive shaft in to have it lengthened the shop supplied a new one.
If you do not find one and your shop can not get one you can have mine for the shipping cost
Kip's41 #606840 01/03/2010 11:17 PM
Many thanks Kip,
I'll keep that in mind if I can't get one a bit more local.
41 Chevy
