0 members (), 77 guests, and 1 robot.
Topics128,030
Posts1,055,428
Members48,422
#60570 05/17/2006 4:37 PM
Apprentice
Apprentice
i took the starter off my 54 235 car and i want to put it on our 48 firetruck
does anyone know if it will fit bolt patern and drive
i know how to wire it but i would ;ike to know itwill fit before i start
the firetruck has original 235
#60571 05/17/2006 5:31 PM
I'm not sure if the '54 is 12 v or 6 v, and there is a difference between starters-
If the '54 starter is 12 v it won't work so good on the 6 v of juice in your '48.
The 6 volt starters (and flywheels) have less teeth than a factory 12v starter and flywheel.
The bellhousings should be the same so the newer starter should bolt right up, 6 or 12.
Compare the number of teeth on the new starter to the old starter to be sure.
#60572 05/17/2006 5:56 PM
A '54 came with a 6V starter. If it's still that way after 52 years the starter will work in your '48 fire truck. By you saying you know how to wire it I'm assuming you already know you'll need a push button switch for it because it has a solenoid rather than a mechanical (foot operated) engagement mechanism.
Quote
True about the flywheels but the starters both have 9 teeth. The teeth are shaped different to mesh with the proper flywheel. Side by side the 6V teeth look fatter.
#60573 05/17/2006 9:32 PM
1938-54 uses the same starter drive. Just bolt it on and wire up a starter button.
My Blog
