7 members (Donf, Gdads51, 55shaker, TUTS 59, Forty9, Donsz, Gray_Ghost),
126
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,056 Posts1,055,799 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | Am in the midst of a frame up resto of a 49 1/2 ton Chevy. My dilemma is whether or not to tear down the rear end to rebuild. The truck was running OK when I started and I'm wondering if this is necessary. As a minimum what should be done to the rear end? Would like to hear thoughts of others who have been there Thanks | | | | | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | If I were on your shoes I would do something about the original 4:11 ratio. Whether you go the Patrick's route or change to a more modern set-up, you will be glad you did something about getting your speed up and your engine rpm's down..
I drive my truck quite a bit. When I plan my route I try to avoid the highway as much as possible. There are times though, when you need to get out there and get moving. I have the Patrick's 3:55's and never go above 60. For me, that was the best money I spent on the truck. It makes it a lot more practical to take on a trip and enjoy..
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
| | | | | Joined: Sep 2002 Posts: 11 Member | | Member Joined: Sep 2002 Posts: 11 | I would at least put in new bearings, seals and lube. If it don't have floating hubs I would check the end play on the axles as well. Easier to do now than a few years down the road.
Just my .02
I know the reality, don’t mess with my fantasy!
Erwin
