| | | Forums66 Topics128,123 Posts1,056,653 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 52 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 52 | I'm looking at buying a title for my Suburban. This title has "SB" in the body style box. the VIN# is GBM409170.
Looks to me like it might work....but sometimes a VIN# has a built in code that links it to a particular type vehicle...what do you think? | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | That does not appear to be a valid Chevrolet truck serial number. I would not buy a number that didn't match the truck. Its likely someone will spot the problem and call you on it eventually.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jul 2005 Posts: 52 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 52 | How can I get a title for it? I don't find any ID VIN# plate on the truck. How could anyone challenge it? How would they know it doesn't match? I'm at a loss to figure out what to do. Any help would be appreciated. Thanks
I've had the truck 15 years. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I believe it should say "sub" in the body style box. The motor or vehicle identification number is usually the serial number on the engine plate. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The answer to your question varies state to state. Check with your local DMV to see what they recommend.
