4 members (Hotrod Lincoln, Mike B, FishinToms53, Peggy M), 91 guests, and 2 robots.
Topics128,119
Posts1,056,648
Members48,450
I'm looking at buying a title for my Suburban.
This title has "SB" in the body style box.
the VIN# is GBM409170.
Looks to me like it might work....but sometimes a VIN# has a built in code that links it to a particular type vehicle...what do you think?
That does not appear to be a valid Chevrolet truck serial number. I would not buy a number that didn't match the truck. Its likely someone will spot the problem and call you on it eventually.
How can I get a title for it?
I don't find any ID VIN# plate on the truck.
How could anyone challenge it?
How would they know it doesn't match?
I'm at a loss to figure out what to do.
Any help would be appreciated.
I've had the truck 15 years.
I believe it should say "sub" in the body style box.
The motor or vehicle identification number is usually the serial number on the engine plate.
1951 3100 Chevrolet
The answer to your question varies state to state. Check with your local DMV to see what they recommend.
