6 members (dt235sd, GMCJammer51, Phak1, Goach2, Southerntruck, NorCal52Suburban), 58 guests, and 0 robots.
Topics128,196
Posts1,057,395
Members48,471
somewhere else.I purchased and installed a new radiator and thought that would solve the leak problem.I checked it yesterday and put in about a gallon and a half of anti freeze and water.Is the old truck leaking out the water pump ? I don't see any leaks when running or sitting? Where else could it be leaking? Any ideas or suggestions?
Located in Missouri where the big snow storm is and temperature is 25 degrees.
It could be your water pump,is there any residue around the bearing or weep hole? It could also be escaping as steam, your temp sending unit, head gasket, heater core, any hose connection.
How's the oil look? foamy?
Antifreeze never really dries so look very closely for the sticky residue it leaves behind
Ray
I'll check that. I drove it quite a bit probably 500 miles since checking it. I bet it is the water pump.Shouldn't involve too much to fix.
A gallon and a half is a lot of fluid to lose. A small leak can leave some residue as evidence. In my case it leaves a white colored residue. If you have a miss at idle, you might want to look at your plugs. My # 3 plug used to look different than the rest and that is where the crack in the head was.
1951 1 Ton Completed
Chevy garage called and they think it is a wrong radiator cap. 48 chevy had a 4 lb cap on it and they replaced it with a 7 lb cap. Garage thinks that is the problem, not leaking now. They want to keep it and drive it on the road in a few days once it quits snowing, if it ever quits snowing.
That doesn't make a whole lot of sense but good luck to them. If a 7 lb cap causes it to use antifreeze, you have a leak somewhere.
I'd suggest it's likely that the higher than design pressure combined with overfilling could well have resulted in overflow ... that's why they put an overflow on the rad after all .... make sure you don't overfill, keep it at least an inch below the fill neck when warm, even 2 or 3", and see what happens - and always check water level when the rad is warm, not cold
I would get a tracer die and a black light. you will find your leak as the die will be left behind
