1 members (Dusty53), 174 guests, and 4 robots.
Topics128,101
Posts1,056,180
Members48,436
#604029 12/24/2009 8:27 AM
Just picked up a Century(big red) welding unit(for a song-50.00-and it works),don't have any info on it,anything would be helpful.American made.
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
Do a google on it and you can probably download the manual for it free..
Geoff
68 GMC 3800
56 JD420C w/JD90 Loader
Thanks Stick.
1953 Chevy Two-Ton
Have used same one for 10 years Century 155 .Only concern is replaced the cable wire feeds thru 3 times. replacement had at Merriam Graves( Air Gas ??). I also went to.23 gauge fluxless.Superior to next size up.
Is yours the (Big Red)220v with the flip up lid on top and horizontal spool?I'm just looking for manuals and what-nots for it.
1953 Chevy Two-Ton
I purchased a Century GS125 portable MIG welder...came with a gas hookup so I added a bottle after issues with quality of flux-core welds on light sheet metal. This particular model has no solenoid gas flow control and the cheesy pinch valve in the handle gave out after 6 months. No solenoid shut-off valve for gas when you released the trigger......had to shut off the bottle after each weld. No replacement parts.
Replaced it with a Hobart 140......there is no comparison...the Hobart was a keeper from day one. Hope your Century model works out for you.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
Moderated by  MNSmith
